Making 3D printable threads in inventor
drm2189
Observer Observer
Message 1 of 13
drm2189
Observer
Observer
The threadModeler add-in is not compatible with the Autodesk Inventor Professional 2024. Is there an alternative tool that replaces it? Or is there a good guide for this? I've found a few YouTube walkthroughs, but none that explain what each variable is to get the right screw size.
Replies (12)
Message 2 of 13
kacper.suchomski
Hi
You can model the thread manually using the coil tool.
Kacper Suchomski
Message 3 of 13
Frederick_Law
Or get a model from McMaster Carr and edit it.
I printed a drain plug from a bolt.
Message 4 of 13
drm2189
Observer
Observer
I was able to import it as a solid. I don't know how to copy the thread into the part I'm making. How do you suggest I do so?
Message 5 of 13
drm2189
Observer
Observer
Thanks for the reply! I am aware that this is a tool that is used. But do you have a recommended step-by-step guide?
Message 6 of 13
MH-J
Hi
The CoolOrange thread modeler will still work with the current versions of Inventor but you will need to edit a couple of text files first.
Follow the steps below
  • Install the app from Apps and then navigate to c:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_threadModeler.bundle\ folder.
  • In Notepad, open the PackageContents.xml file and edit the string SeriesMax="Ir24" to SeriesMax="Ir30".
  • Save the file.
  • Now, in the Contents subfolder, open the coolOrange.ThreadModeler.Inventor.addin file in Notepad and delete the line 11 with the parameter SupportedSoftwareVersionSmallerThan.
  • Save the file again.
  • Now run Inventor. In the Tools > Options > Add-ins ribbon, open the dialog and unlock and load the coolorange-ThreadModeler plugin.
This is credited to the site below.
https://www.cadforum.cz/en/true-3d-models-of-threads-in-inventor-2022-and-2021-tip12962
Mike
Message 7 of 13
Frederick_Law
Assembly.
Put the part you're making and solid into assembly.
Add feature on the part to locate the thread.
Or sketch and add what you need on the solid.
Message 8 of 13
drm2189
Observer
Observer
This worked perfectly, thank you!
Message 9 of 13
MH-J
You're welcome.
It's not a perfect solution, this functionality should be within the core Inventor package and not something created by an external developer. Come on Autodesk, sort this out!
Mike
Message 10 of 13
wrobertsZWDP6
It's almost ridiculous that this feature is not part of the standard modeling tools in 2024. 3D printing has been part of the design process for a long time now.
AutoDESK,
Get this built into the next service pack ASAP!
Message 11 of 13
christopher_hamm86JPG
Community Visitor
Community Visitor
Worked perfectly. Thank You
Message 12 of 13
revyakinHNHG3
Small correction: the line to delete in coolOrange.ThreadModeler.Inventor.addin is "SupportedSoftwareVersionLessThan", not "SupportedSoftwareVersionSmallerThan" 🙂
I guess see you all in this thread when the current version of AI is 31?
Message 13 of 13
johnsonshiue
Hi! Simply set the less than version to 100.
Software Test Engineer
