Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Placing 360 CAD into Inventor --> No bodies read from file
etiennegignac
etiennegignac
Good day.
I am experiencing an intermittent "bug".
New designs created in fusion 360 will import blank with the warning "No bodies read from file".  Every other instances of that problem I find googling doesn't seem to apply.
I simplified the process as much as possible:
- New fusion 360 design consisting of a single body which is just an extrusion (test.fusiondesign)
- New blank inventor assembly file
But I have 2 fusion designs which I am able to import, which are also a single body (Hitch bar v2.fusiondesign).
I am flabbergasted as to why one design will import just fine where the other ones will not.  All designs are showing up in m Fusion360 "drive" through the desktop connector. I am also project admin.
Any help is appreciated.  I have taken a bunch of screenshots but can only attach 3, hopefully it's clear enough.
etiennegignac
Using Inventor 2023, build 208.
etiennegignac
Warning after import.
etiennegignac
This hitch bar design I am able to import and work with.  Not sure what the difference is.
CCarreiras
Try to Refresh the cloud, sometimes it get some time to refresh the file.
Also try to download the file locally in your PC and open it.
CCarreiras
etiennegignac
The test file is 4 days old now so I doubt that's it.  How do I force a refresh on the cloud?
johnsonshiue
Hi! If I recall correctly, Inventor only imports surface bodies and solid bodies from Fusion design, not mesh or Tspline. You will need to convert them to bodies. If possible, please share the f3d file here or send it to me directly [email protected]. I can try it on my machine to understand this behavior better.
Many thanks!
Software Test Engineer
