Inventor Forum
Exporting Images
1 REPLY 1
lkirit2000
576 Views, 1 Reply
Exporting Images
Please see the attached image of trestle in extended position. When export,  to create an JPG image with extended position , the image comes in closed position. STEEL GALVANISED TRUSTLE 0.45 M ASSY-9.jpg
1 REPLY 1
johnsonshiue
in reply to: lkirit2000
Hi! I think this is one of the most confusing behaviors in Inventor, I have to admit. The reason is that when the non-Master PosRep is active, the file cannot be saved as is. Only PosRep:Master can be saved. As a result, export (as a save operation) can only happen to PosRep:Master. The workaround is to insert the assembly to an other empty assembly and then activate the PosRep in the subassembly. Then export it to an image.
Many thanks!
Software Test Engineer
Technology Administrators
