Exporting from SketchUp 2017
I am here to ask if anyone knows of a way to export a 3D model from SketchUp 2017 to Inventor as a Part. I hope to hear back soon from anyone who can help.
JDMather
Save as *.stl
Import *.stl into correct unit file (inch or mm).
Run the AutodeskMeshEnabler to convert to solid body.
swalton
As far as I can tell, Sketchup is a mesh modeler, not a brep one.  I don't think you will get a watertight, ready to manufacture model from a Sketchup export.  Instead, just remodel the object and move on.
Here is the sketchup help file about 3d exports.
https://help.sketchup.com/en/sketchup/importing-and-exporting-cad-files#export-3d
Steve Walton
Inventor 2025
Vault Professional 2025
Gabriel_Watson
OBJ format is another option too. This similar article describes how to use Mesh Enabler to convert the imported geometry (mesh) into a proper solid.
https://forums.autodesk.com/t5/inventor-forum/obj-file-to-a-solid/td-p/8240032
Keep in mind that you may need to repair it further and maybe even save the file as STP then re-import it again to reduce size/unnecessary complexities.
johnsonshiue
Hi Andres,
The geometry you created in SketchUp may not have the precision Inventor requires. I suggest you look into Fusion 360. It has more versatile modeling environment.
Many thanks!
Software Test Engineer
