- Mute
- Permalink
- Report
Hello folks! I'm looking for either a solution to our issue OR verification that the issue is happening to others.
One of the guys in my office noticed that when we export an Inventor .idw file to an AutoCad .dwg file (for use in-house) and open it in AutoCad, the Hidden Line layer has changed from a dashed line to a solid (continuous) line. It still stays in the Hidden Line layer, but the linetype changes. We have also noticed it in our Tweak Lines from Presentations as those are normally dashed as well. In fact, any dashed line layers turn into solid lines.
We have tried Exporting a PDF as well as Exporting an Inventor DWG and only the AutoCad Export has this issue.
Listed are the things we have tried:
- Starting with a Inventor .dwg still repeats the problem
- Inventor's standard templates as well as custom drawing templates are affected
- Exporting as AutoCad .dwg in a AutoCad Mechanical 2019, AutoCad 2018, and AutoCad 2004 format all repeat the problem
- The problem did not exist in late Inventor 2018
- Tried saving/opening with different combinations of three different computers
- Autodesk TruView shows the same as AutoCad
We are currently running Inventor 2019.1.1 on 64-bit Windows 10 Pro (Version: 1803, Build: 17134.319). I did upgrade my computer to Inventor 2019.1.2 and the problem persisted. I strongly suspect that the issue started when we upgraded to Inventor 2019, but I don't have any conclusive evidence other than it didn't happen when we had Inventor 2018.
Like I said, any help in solving would be appreciated or at least verification that other people are affected.
Matt
