Export to IFC
Export to IFC
Export to IFC
Is there any to export a model (a steel frame, for example) to .IFC, but keeping all objects separated?
I have a model of complex steel structure, and I need to export it to IFC and then import this into SpaceGass (structural engineering analysis software).
Currently I can export successfully (Through Environments>BIM Contents>Export Building Components). Which works, however all of the individual steel members are connected together (essentially, the entire model is 'one element').
I need a way to export the model, so that each member is its own entity. That way, I can analyse each member in the analysis software.
I do not use Inventor and have downloaded it solely for the purpose of converting the original file into a format that I can input to Spacegass.
Any help would be much appreciated.
Cheers
blair
You would need to export the Inventor file to a neutral format such as IGES or a STEP file and then import the neutral format.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Thanks for the reply, but I must still be doing something wrong: See attached for the error message when I try to import the .STP file
blair
Can you try with the IGES format, this normally is the preferred format.
Delta Tau Chi ΔΤΧ
Hi Blair,
Unfortunately Spacegass cannot read .IGES filetypes.
I'm limited to .ifc and .step
I have the same problem. I want to export an Inventor project to IFC with separated objects and the iProperties I've added to al de objects. Is there a solution already?
Any input is warmly welcomed and very much appreciated!
Thanks!
