You could modify the INI file that is responsible for the export to DWG. Please check this article below for more info,
Hope it helps.
Thanks Lam. At the moment, setting the default to AutoCAD DWG is not possible. Please log an enhancement request in this inventor idea station site below,
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
For saving the PDF options.
Good day to you.
Just wanted to check with you for an update. Please let us know, if you need further assistance.
We will be glad to assist you further.
Your understanding and support is greatly appreciated. Have a great day !
Vinod.
can I ask if there is any change in the save settings?
I also need to set the saving .idw to .autocad .dwg by default.
Thank you.
(Inventor 2019)
Hi Milan,
I am not aware of an option to set the Save DWG file to AutoCAD DWG. It should obey the last used file type.
Many thanks!
Hi Johnson,
Thank you for your response.
You are right, but when you turn off Inventor and then turn on Inventor, you have to set the export to AutoCAD .dwg again.
The ideal option would be if I could set up this option somewhere in the registers.
Thank you.
