Announcements
How to trim/edit in assembly to make intersect and join parts
tis07282015
tis07282015
See attached files. Is it possible to miter trim channels and make a frame to desired size .
While ago I posted about factory file, got answers but I steel don't know where should I look for factory file. Possible to have steps to find factory file ? I am not so familiar to Inventor.
Sam
Replies (9)
JDMather
The easy way to do this is in the Frame Generator environment of Inventor.
Sergio.Bertino
Autodesk Support
Autodesk Support
Hi @tis07282015,
Thanks for your post.
As @JDMather said, you can easily use the Frame Generator which uses a Skeleton model reference geometry:
Frame Generator overview
Please let us know how it goes
Sergio Bertino
MFG Technical Support Specialist
tis07282015
I finally created a frame. Now I want to change size of frame. That means I have to edit skeleton, tried to change dimensions, no option there. Is is possible to edit and change frame size ?
Sam
leowarren34
I believe it to be dynamic so you shoudl just have to change the skeletons dimensions and parameters.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
tis07282015
How do I change skeleton dimensions. It does not allow me to do that.
leowarren34
Double click on the part in the assembly hierachy.
Leo Warren
blair
To use the Frame-Gen module.
help for Frame-Gen:
https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-953F560A-C2D3-4031-8348-762054C7C779
 and the lower one contains a good video:
https://help.autodesk.com/view/INVNTOR/2019/ENU/?caas=caas/video/youtube/lesson/146313-courseId-1003...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
SBix26
The part that you originally created to define the frame dimensions is the part to edit.  The Skeleton part is derived from that part and is not editable.  You are looking too far down in the assembly hierarchy.
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
Sergio.Bertino
Autodesk Support
Autodesk Support
Hi @tis07282015,
Please let us know how it goes.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Sergio Bertino
