Inventor Forum
export stl file format assembly as each part
11 REPLIES 11
Message 1 of 12
6372 Views, 11 Replies
hi
i have doing desing mold parts and make assembly and i want transver novacast software as Stl file format
but i can't save stl format my assembly as each part but it is made at inventor 2010 but assembly union but i don't want to
11 REPLIES 11
Message 2 of 12
STL export is only avalaible from parts. Derive your
assembly into a single part file for STL output
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 3 of 12
but i am not save my assembly as a part
i have to save my assembly , i don't want to union assembly as a part
Message 4 of 12
A derived part leaves the original assembly intact and
untouched. Perhaps I do not understand your need.
Expert
Expert.
AIP 2008 SP3,
Message 5 of 12
JDMather
This has not been the case for several releases. I think Inventor 10 Extension (no not 2010) would save an iam as stl file. But it is a single stl file. I think the OP is asking how to save each part in an iam as a separate stl file.
Message 6 of 12
JD, you are correct. My thought path was stuck on the single
STL file.
He will have to activate each withing the assy file (or open
each one) in order to create separate STL files.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Implementation Certified Expert.
399-6615
AIP 2008 SP3, AIP 2009-SP1 PcCillin AV
Message 7 of 12
I know this is an old thread but I think it's relevant to my question.
Does anyone know of a macro to exports all the parts in an assembly as separate stl files with one mouse click.
I use the stl output in separate rendering and analysis packages so I need all the files to have a common origin and orientation.
Currently I achieve this by hiding all parts except the ones I want in a given stl file and export that while in the assembly environment.  Multiple parts with a common material in the rendering app, I would export  as a single stl by hiding everything else first.
In large assemblies this obviously can be a bit arduous.  Has anyone come accross a macro that automates this?
Hugh
Message 8 of 12
KevinLi-Autodesk
Hi HughUK,
When you export the assembly as STL file, click Options... button to launch STL File Save As Options dialog box, select "One File per Part Instance" from Structure dropdown list (see attached image), then all the parts in an assembly can be exported as separate stl files.
Hope it helps.
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 9 of 12
in reply to: KevinLi-Autodesk
Hi Kevin,
Thanks very much for that.  It's useful to know that when we upgrade there is a much easier method.  Unfortunately at the moment we are still using 2010 and will be for the next month or two.
Hugh
Message 10 of 12
KevinLi-Autodesk
Hi HughUK,
Sorry to forget to ask your Inventor version that used (  I suppose you are using Inventor2012 🙂 ).
I double check it in Inventor 2011 and see this function is already available, so you just need to upgrade your Inventor to 2011 to do it.
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 11 of 12
Thanks Kevin,
Unfortunately I am in the hands of the company's IT dept.  Thier priority is a WinXp to Windows 7 upgrade before they upgrade Inventor.  As a company, we've basically wasted the 2011 subscription and I'm guessing that you will be on the brink of releasing 2013 before we get 2012.
So I was hoping that in the days prior to this facility being native to Inventor, someone had come up with a Macro to do it in 2010.
Thanks again for your time.
Hugh
Message 12 of 12
christian.postma
in reply to: JDMather
Update:
By Inventor 2022 we can save a complete assembly as one STL via File > Save a copy as. In the "Save as type:" dropdown list choose "STL Files (*.stl)", name the file and hit save!
