I am using Inventor and I started to use Autodesk Simulation Multiphysiks to check components and assemblies as it is convenient to stay in the same environment.
In order to use the simulations I have to extract the deviation Value on a line on the surface as a plot. Best would be as a text or Exel file.
However when I try use the "Create a path Plot" option the program is plotting the value at points of the simulation and does not interpolate along a line. Even more I did not find any methode to select just points on the surface.
You can tell me I should start to learn Simulation Multiphysiks from the scratch. Could be true, but do not have so much time and I am using it because it is similar to Inventor, otherwise I could use other software.
Many thanks in advance,
Karsten Schuhmann
