So, I have hundreds of top level assemblies, each containing multiple subassemblies. Many top level assemblies contain the same subassemblies. I exported each one when i made them, and use them in excel querries, pivot tables, ... to collect and work with the data from the entire project. Everything works as planned, but now I want to change some things in several bottom level assemblies (mostly descriptions). What I don't want to do is go through every single top level assembly, update it and export all the boms again manually.
Is there a way to export multiple boms at once? Or even better, create a live link between the inventor bom and the xls file?
Hi! I believe you will need to use iLogic to automate the task. There will not be a link between Inventor and the exported xls files. The "update" is simply exporting it again.
Many thanks!
I was looking into that as well, I could use this snippet right here:
ThisBOM.Export("Structured", ThisDoc.FileName(False), kMicrosoftExcelFormat)
But this seems to just export it to the folder that the assembly itself is in, would it be possible to change this path very easily?
Also, I have an XML-File for the BOM customisation, is there a snippet that'll read this file so the customisation doesn't have to be imported manually?
