Export from Inventor to Autocad DWG displaying Iproperty name not Value
cliff.kelly
cliff.kelly
Hey Friends,
I am running into an issue when exporting AutoCAD DWG's from Inventor where the Iproperty name is displaying, but not the Iproperty value.
E.G. Iproperty name "Part Number" is displayed in the AutoCAD DWG instead of the value "AP5"
Is there a way to have the value export instead of the property name?
Cliff
johnsonshiue
Hi Cliff,
It should work. The behavior does not sound right to me. Also if it were the iProperty name exported, it should be "Part Number", not "Part_Number." Could you provide an example file exhibiting the behavior? I would like to take a look and understand it better.
Many thanks!
Software Test Engineer
cliff.kelly
Hey Johnson,
Thank you for the reply. Please find attached the Inventor IDW file and (1) of the Exported AutoCAD DWG files.
Let me know what you can find.
Cliff
salariua
@cliff.kelly
Take OFF Convert Symbols to Drawing Blocks in File Save Options dialog like this:
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
