I was (and still am) officially stumped this morning by one of my workers when they asked me what these columns and icons mean in the Parts List.
Granted, the "Balloon" and the "Part" icons are a "gimmie", but for the life of me I can't recall, nor find the explanations/descriptions of the other columns/icons.
This was stumbled on when he found the parts list was listing the same parts twice and the only difference was the icons (one instance has the "Part" icon, the second instance of the same part in the Parts List has the "horizontal graph" icon.
Someone's got to know.
Jim O'Flaherty
Hi TheAngryElf,
The balloon icon shows if the item has been ballooned on the drawing
The +/- icon is for expanding subassemblies in the parts list when the BOM is set to show All Levels
The icon that looks like a block on a book, indicates an content center part
The icon that looks like a bar graph indicates that more than one part file has been "rolled up" or combined under one part number.
I hope this helps.
Curtis
Hi Ebrahim60,
Just to clarify, the bar graph icon often does relate to Frame Generator parts, but it is not an indicator that the part is a Frame Generator part.
That icon indicates that two or more components have the same part number and have been "rolled up" or merged as the same item. This is often the case with Frame Generator parts, but not always the case.
Here's a quick video showing the part number row merge settings:
I hope this helps.
Curtis
Thanx for clarification, coz we usually gave different names for different parts I didn't realized it
I guess that's part of the confusion. The parts with the "graph" are, in our case, not Frame Generator parts, nor have they been "rolled up".
In this case it's simply multiple instances of the same part used in the assembly.
Typically these would all be called out once in the parts list and then a total given for the quantity, but for whatever reason, we found this assembly's part list didn't do such. What is even more confusing, the part is not only listed twice, but each listing has a different quantity. AKA if there are 10 of these parts in the assembly, one instance of the part in the parts list shows it as having 6 and the other instance shows there are 4.
I haven't had the chance to dive into the assembly file as of yet (many other fires at the moment) but I'm just wondering if in fact the designer at some point did perform a "promote" or "demote" in the process of building it. It's a command he recently "discovered" and was found to be using it as opposed to doing a "copy & paste" or "copy design", then blamed Inventor for removing the parts out of the original assembly he "promoted/demoted" them from.
Yeah, don't get me started on that one here, it won't go well....;)
Jim O'Flaherty
Hey,
this helped me fix my own problem, indeed the parts list get messed up when you seem to use 'promote' or 'demote' command. Same as you it results in exact same parts shown twice in BOM with different QTY's, neither are correct. Nowhere was a solution found, i discovered turning those parts to 'phantom' and back to 'normal' fixes the issue.
There might be another solution but i didn't found any on the forums or trying myself.
