Inventor Forum
Export DWG Autocad in Inventor 2018
4 REPLIES 4
411 Views, 4 Replies
Good day,
When I import DWG in Inventor 2018 some draw are completely out of scale.
Tags (3)
4 REPLIES 4
Chancellor.Kurre
I'm guessing this dwg was originally created in AutoCAD? Inventor does not allow edits on AutoCAD dwg files, only on Inventor created dwg files. Hope this helps!
in reply to: Chancellor.Kurre
Dwg was create with AutoCad 2018 and imported on Inventor 2018 with
copy/paste. With other drawing was perfect but with someone else when
imported are out of scale.a line of 38.1mm. leght can be 530.3mm. or 900mm.
and for me is a problem
Today I tested with a SW and solved all problem,...but I spended money on
Inventor.
##- Si prega di inserire la vostra risposta sopra di questa linea -##
johnsonshiue
Hi! I believe it is related to MEASUREMENT setting in the dwg file. The geometry in an AutoCAD dwg file may not be true-scaled. To ensure that, you need to set MEASUREMENT to 1. Then, it will be imported correctly.
Or, you simply specify the import unit as "mm" as opposed to the dwg document unit "inch."
Many thanks!
Software Test Engineer
Solved, thanks to everybody.
Have a good day
Elio from Italy
