Good day,
When I import DWG in Inventor 2018 some draw are completely out of scale.
Solved by johnsonshiue. Go to Solution.
I'm guessing this dwg was originally created in AutoCAD? Inventor does not allow edits on AutoCAD dwg files, only on Inventor created dwg files. Hope this helps!
Hi! I believe it is related to MEASUREMENT setting in the dwg file. The geometry in an AutoCAD dwg file may not be true-scaled. To ensure that, you need to set MEASUREMENT to 1. Then, it will be imported correctly.
Or, you simply specify the import unit as "mm" as opposed to the dwg document unit "inch."
Many thanks!
