Export assembly to .obj, while keeping the correct names of its parts?
nicolasG63E5
1,910 次查看
4 条回复
1 条消息(共 5 条)
nicolasG63E5
Hello helpful Inventor Forum,
I am looking for a way to export a medium Assembly in Inventor 2019/2022 to .obj, to use it in a web application.
The problem is, that all entities in the single-file .obj are numbered instead of their original names. I tried every option in the export-to-cad function, to no avail. Is there maybe a plugin for this?
My search in several forums did not reveal up anything about this, but I was told that somebody managed to do this some time ago.
Thanks a lot for all the help over the years. I hope someone can hint me to a solution here, too.
Best regards
NC
0 个赞
已接受的解答 (1)
1,911 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
johnsonshiue
Hi! If I understood your request correctly, this can be set in the Options. When exporting to obj, click on Options -> Structure -> select "One file per part instance." You will get one obj per part. Is this what you were looking for?
Many thanks!
Software Test Engineer
0 个赞
3 条消息(共 5 条)
nicolasG63E5
Thank you for the fast reply.
Sadly, this option is not a solution here, because I need a single obj.-file containing all instances (correctly named) of the assembly.
Besides, when I tested this option, the resulting "Assembly".obj file failed to load in any viewer on my machine, including Blender.
0 个赞
4 条消息(共 5 条)
nicolasG63E5
已接受的解答
For anyone with the same Problem, I have got the solution from the somebody I mentioned in my question:
The trick is to open every part in the assembly and rename the volume (or every volume) in it to the desired name. When exporting, the single-file-.obj contains the instances named after the contained part-volumes.
Another questions that came up was: how can I control the names of the part-volumes?
I'd like to do it in a less tedious way, or to make it inherit the name of the file.
0 个赞
5 条消息(共 5 条)
illustratorjason
Community Visitor
Community Visitor
Too bad Blender can't open U3D file formats. That is what I work with. It keeps part names, and assembly structures.
0 个赞
