Export and merge multiple BOM
emanuel.karlsson
emanuel.karlsson
Hello!
I don't know if this work in inventor or vault but I would like to be able to export a full BOM-list of multiple projects into a spreadsheet like excell.
Is this possible? If so, could someone share their workflow?
edit* did not explain the correct problem.
// Emanuel
JelteDeJong
You could try to add the 2 assemblies into 1 "temporary" assembly and export the bom of that new assembly.  If you need to do this often you could write an iLogic rule to do that for you.
Jelte de Jong
Blog: hjalte.nl - github.com
johan.degreef
@emanuel.karlsson  I think you can do that, just export to excel.
But we also have need for a much more flexible BOM managment.
A full BOM (works)
A BOM of a separate sub assembly (works)
A BOM of the full minus a subassembly (Does not work?)
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
