Decimal separator in hole notes
RSNewton59
RSNewton59
Hi, all.
In compliance with BS8888 I have changed my decimal point to default to a comma on my work. Apart from the hole notes. Can't figure out how to do this. Anyone manage it?
 The 1.75 doesn't seem to be editable as such.
JelteDeJong
You can change this in your styles. Right click on the "hole notes" and select "Edit dimension style"
And check the following:
Jelte de Jong
Blog: hjalte.nl - github.com
RSNewton59
No, I've already got that (see my image) it's the 1.75 bit I'm trying to fix!
JelteDeJong
Sorry missed that. These are a bit more difficult to change. You will find an excel file in your design data folder with all thread names. For me that file is located here:
C:\Users\Public\Documents\Autodesk\Inventor 2022\Design Data\XLS\en-US\thread.xls
In there you will find a tab for each thread type. You can alter the "Custom Thread Designation" column with a different decimal separator.
When you save excel and restart Inventor you will notice that your drawing is NOT updated. You will need to reset your hole with the correct information in your part. Only then will you see the changes in your drawing.
Here you see that I have the old and new data in my hole feature:
Jelte de Jong
RSNewton59
Thanks, irritatingly our IT dept has made that folder read only so I'll have to gt them to do it!
