Exploding Sketch Blocks During Copy/Paste
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Has anyone ran into an issue of sketch blocks messing up when being copy/pasted?
The example below:
The sketch block as it exists.
Before
The sketch block as it exists AFTER simply copy/pasting the BLOCK using the browser. Look how the splines are messed up. If you try doing anything with the sketch (scale, rotate, etc.) it will cause the sketch lines to jump to match the splines and mess up the drawing.
After - Note the splines
After & following modification of the block
Note that if I copy the sketch and sketch lines, things are fine. So that is the current work around. Would be nice to be able to use the sketch block functionality to copy things as that is what one would assume it's there for...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
