Inventor Forum
Exploded view tweaks/trails Inventor 2011
4 REPLIES 4
bibleje
479 Views, 4 Replies
Believe it or not the company I just started working for is still on IV 2011.  I know I know.  Anyway I am making some exploded views for the shop using hose runs.  This particular hose run is attached on both ends to 2 different valve bodies.  How do I show the end fitting attached to the second body?  Hopefully the attached clip will show what I am talking about.
Thank you,
...wanting so bad to upgrade...
John E. Bible
kelly.young has edited your subject line for clarity: tweaks/trails...
4 REPLIES 4
chrismudd
in reply to: bibleje
I may be misinterpreting what you're asking, but could you just do a breakout view once it's in the drawing?
bibleje
in reply to: chrismudd
Hopefully this will clear it up for you.
Thank you,
John E. Bible
kelly.young
@bibleje I'm assuming you have tried to turn on the visibility like the upper tweak shown in the images?
Are you trying to show the tweak in a video presentation or on the .idw drawing?
If it is on the drawing you can create a sketch and draw in the tweak lines you want. It is quick and no special setup would be needed.
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
@bibleje  With the 2011 kind of running off memory, do you have any additional information to supply?
Did you get you presentation tweaks figured out?
Technology Administrators
