Believe it or not the company I just started working for is still on IV 2011. I know I know. Anyway I am making some exploded views for the shop using hose runs. This particular hose run is attached on both ends to 2 different valve bodies. How do I show the end fitting attached to the second body? Hopefully the attached clip will show what I am talking about.
Thank you,
...wanting so bad to upgrade...
John E. Bible
kelly.young has edited your subject line for clarity: tweaks/trails...
Solved by kelly.young. Go to Solution.
@bibleje I'm assuming you have tried to turn on the visibility like the upper tweak shown in the images?
Are you trying to show the tweak in a video presentation or on the .idw drawing?
If it is on the drawing you can create a sketch and draw in the tweak lines you want. It is quick and no special setup would be needed.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
@bibleje With the 2011 kind of running off memory, do you have any additional information to supply?
Did you get you presentation tweaks figured out?
