Unable to select sketch with "Exit Sections" feature.
However the sketch is attached to the correct view and is not defined as "sketch only"
Solved by johnsonshiue. Go to Solution.
Hi! The Slice View workflow is a bit unintuitive. In order to pick a slice sketch, you do need a projected view. You cannot create a slice within a base view. Just create a projected view at the top. You will be able to select the slice sketch.
Many thansk!
Ok, thank you for your answer @johnsonshiue !
I think I misunderstood the feature. It works only on a projected view, and moreover on an isometric view...
See below the result I was expected :
