Excel VBA to Save Copy As
Message 1 of 9
Hi all,
I'm trying to use Excel VBA to call Inventor to open an idw drawing, then Save Copy As dwg for AutoCAD. I found, in VBA, the class Document that has a SaveAs method but when I run the code it would not compile, giving me the message "Object doesn't support this property or method".
Can anyone point me to the right direction? My main goal is to use Excel VBA to save an idw drawing to an AutoCAD dwg file as a new copy. Thanks.
Danny
Replies (8)
Message 2 of 9
schmidmi
Hi Danny -
Thank you for your question.  I was able to create a sample VBA script that takes known *.dwg file and save it as a *.idw.  Take a look at the example for any differences there are between it and yours.
Public Sub SaveAsSample()
    Dim sFilePath As String
    sFilePath = "C:\Temp\Drawing1.dwg"
Dim oDoc As Document Set oDoc = ThisApplication.Documents.Open(sFilePath) Dim sFilePathCopy As String sFilePathCopy = "C:\Temp\Drawing1_copy.idw" Call oDoc.SaveAs(sFilePathCopy, True) oDoc.Close End Sub
Let me know if you continue to have trouble.
Thanks!
Michael Schmidt, Principal Engineer
Message 3 of 9
Hi Michael, thank you for your reply. I'm sorry I have been late in trying this. I actually have stopped checking the message box a day after I posted the question, thinking that no one had an answer.
What I needed was actually the other way around. I would like to have VBA (from Excel) open an idw and SaveCopy as dwg.
Nevertheless, I tried your solution to see if I can run it. When I ran it, I received an error in the Set oDoc line (underlined below) saying ActiveX component can't create object. Do you know what it means and how to fix it? Thanks again.
    sFilePath = "C:\Inventor Tutorial\GEMMA MEDWAY MODEL\2000 - Plenum Drive\Drawings\Drawing1.dwg"
    oDoc.Close
End Sub
Message 4 of 9
MechMachineMan
Have you properly connected to inventor?
ie;
Dim oInvApp As New Inventor.Application
Set oInvApp = GetObject("", "Inventor.Application")
'Do Things
oInvApp.Quit
Set oInvApp = Nothing
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 9
Hi Justin,
I did not include the code you proposed at first. After I added it, I am still having the same issue.
'Dim oInvApp As New Inventor.Application I disabled this and replaced with the line below because VBA says I'm using "New" improperly
Dim oInvApp As Object
oInvApp.Visible = True
Set oDoc = ThisApplication.Documents.Open(sFilePath) 'This is where I get the runtime error 429 --> ActiveX component can't create object
oDoc.Close
oInvApp.Quit
End Sub
Any help would be appreciated. Thank you.
Danny Tan
Message 6 of 9
MechMachineMan
Change this ThisApplication to oInvApp.
Opening the app doesn't do much if you don't reference the object when you
actually need to use it. Ha
Justin K
Message 7 of 9
MechMachineMan
Justin K
Message 8 of 9
MechMachineMan
Justin K
Message 9 of 9
Hello Justin,
I've tried your solution; it works. Thank you. Sorry for the late reply; I had wanted to roll out the solution to my team and make sure it works before accepting as solution and closing out this topic.
Thanks again, and Happy Holidays!
Danny
