Excel Thick Border Bug In Drawings
MKE_Howard
MKE_Howard
Hello hello, I have an issue with the thick borders in Excel. Basically, I imported my table into Inventor, but the lines at the top and on the left don’t appear thick. I thought it was a bug in Excel, so I moved my table away from the corner, but unfortunately, the same issue persists.
johnsonshiue
Hi! I could be wrong but the table border line weight seems to go with the Layer line weight. Go to the layer hosting the table and change the layer line weight.
Many thanks!
Software Test Engineer
MKE_Howard
Hello, when I select my Excel table, there's nothing in the layer tab because I used :
Its easier for me this way to make modifications... Tbh it's not a big deal I just wanted to point it out.
Thanks Johnson
johnsonshiue
Hi! I am sorry that I thought you use General Table. You were using the OLE object, which my explanation does not apply to.
Many thanks!
