Nest Error 'A dependency is disabled.'
darryn_mott
darryn_mott
I am getting an error that i cannot find any information on.  The error occurs when creating the nest and the error is  'A dependency is disabled.'
It appears to nest correctly.
I created another Nest file earlier in the day and had no problems.
Inventor 2024
WillsonLeng
Hi @darryn_mott
The error indicates there are some dependency features are disabled.
Is that possible you can share your data to us, and we can check which dependencies are disabled?
darryn_mott
Good morning,
I cannot share the data but I found that the error rears it's head if you 'disable' some source files that you do not want to nest.  If these files are enabled, the error goes away.  It errors nest studies that are not the same thickness.  Most of the parts on this nest is derived from a single 'skeleton' file, (none of which are the disabled parts) so that may tie into the errors.
