Inventor Forum
Event trigger not working
3 REPLIES 3
amarcoc
659 Views, 3 Replies
Hi.
I create itriger for the first time.
The event does not trigger any way.
If I create a new file, the rule will not run, and even the event trigger is removed from the list.
I am using external rule.
What am I doing wrong?
I am using latest version 2017.4.1
3 REPLIES 3
mdavis22569
in reply to: amarcoc
Can you share the code .... or a code and files?
Mike Davis
amarcoc
in reply to: mdavis22569
A simple  messagebox on external rule will not run.
It does run if it is internal rule.
MessageBox.Show("Test", "Error!")
lmc.engineering
I'm not actually sure this is possible as I believe the itriggers only work at the document level.
To get around this you could add a rule to your document template file that is set to run the external rule, and have itrigger within the document rule.
Hope this makes sense
All the best
