Error while trying to direct edit imported step file
Hi there,
I am working on a project that was native to Solidworks. It was converted for me into .stp, but I also have the .sldprt. I have imported directly from the .sldprt, tried a 3rd party conversion software to convert from .sldprt to .stp, and I have imported the provided .stp.
Every time I try and direct edit the part, I get an error. "The attempted face operation did not provide a meaningful result". I have also gotten an error when attempting to delete faces. Is there anything short of remodeling that I can do to work on this part in Inventor?
I have attached the 2 original and the converted file for reference. I will include this was designed in China just in case there is a language error possibility.
Thanks in advance!
johnsonshiue
Hi! The part body checks fine. I suspect the small radii (fillets) might cause some problems. Please show us where exactly you want to perform Direct Edit at.
Many thanks!
Software Test Engineer
The fillets definitely cause the problems. I tried deleting the fillet with delete face and heal, but that also gave me an error. Until I tried deleting the loop of fillets. Then it worked and the subsequent direct edit worked.
Thanks for leading me to the solution!
