This engineering drawing has a component that remains completely jagged regardless of the viewing mode I choose. I've conducted several checks in 3D, and it still appears this way in 2D
Solved by kelvincosta. Go to Solution.
If it is not shaded, do you still see the jagged lines?
What are your settings here?
Try changing the "Use Bitmap" to offline only and see if that makes any difference.
no is not suppose to be shaded. It is supposed to be solid like the others.
I think that it may be a configuration on the part file, because every drawing that has this file it looks like the same. But I am not sure what could be
Hi! As Kirk mentioned here, it might be due to the shaded view setting in Drawing Doc Setting. If possible, please share the files in zip here or send it to me directly. I would like to understand the behavior better.
Many thanks!
it did not work guys. It might be a inventor bug that I gave up. thanks for the help
Hey guys,
I found the error
in the tree of the assemnly, if the part is selected as "reference" than it will show dashed. But if is select as default, then it will be normal
