When I opened Inventor Pro, I had these errors pop up.
Cannot open XML file: \Design Data\Lighting.xml.
Cannot open XML file: \Design Data\Balloon.xml.
Cannot open XML file: \Design Data\CenterMark.xml.
Cannot open XML file: \Design Data\DatumTarget.xml.
Cannot open XML file: \Design Data\Dimension.xml.
Cannot open XML file: \Design Data\FeatureControlFrame.xml.
Cannot open XML file: \Design Data\Hatch.xml.
Cannot open XML file: \Design Data\HoleTable.xml.
Cannot open XML file: \Design Data\Id.xml.
Cannot open XML file: \Design Data\Layers.xml.
Cannot open XML file: \Design Data\Leader.xml.
Cannot open XML file: \Design Data\ObjectDefaults.xml.
Cannot open XML file: \Design Data\PartsList.xml.
Cannot open XML file: \Design Data\RevisionTable.xml.
Cannot open XML file: \Design Data\SheetMetalRules.xml.
Cannot open XML file: \Design Data\SheetMetalUnfold.xml.
Cannot open XML file: \Design Data\Standard.xml.
Cannot open XML file: \Design Data\SurfaceTexture.xml.
Cannot open XML file: \Design Data\Table.xml.
Cannot open XML file: \Design Data\Text.xml.
Cannot open XML file: \Design Data\ViewAnnotation.xml.
Cannot open XML file: \Design Data\Weld.xml.
Cannot open XML file: \Design Data\WeldBead.xml.
Cannot read texture image \Textures\Chrome.dds
How do I fix this issue, please help asap. Thank you very much.
Solved by jhackney1972. Go to Solution.
Your project file reference to your design data (styles library) is not set to the actual location of the files...
OR
If your project file says "Default" in this location, then your design data entry in your Applications Options is not set to point to your the actual location of the design data files.
John Hackney, Retired
