Error message while trying to install Inventor 2016
Message 1 of 12
I'm trying to install Inventor 2016 but an error message appear at the beginnig of the installation process.
"There is a problem with Windows Installer package. A DLL required for this install to complete could not be run"
Here is a screenshot of what i see.
Anyone have a solution for this ?
I tried to disable the firewall/ antivirus, but no change.
Replies (11)
Message 2 of 12
admaiora
I think that you haven't downloaded all the install files.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 12
Mark.Lancaster
@Anonymous
Welcome to the community...
To add to admaiora posting..  Are you trying to install your applicaiton uising the Install Now or download manager method?  If so stop and use the Autodesk Virtual Agent and follow the download links to your application.  First dOwnload all the parts for your software.  Then go to your download folder and extract (double click) on part 1 and after a few seconds the extraction will prompt you to extract to C:\Autodesk.  Once the extraction is finished the installation will start.
Mark Lancaster
Message 4 of 12
mcgyvr
Its recommended to download the files via the Autodesk Virtual Agent..
And make sure you have downloaded all files..
Inv 2016 is 3 files that need to be downloaded.. After all 3 are complete double click on the one with an exe extension to start the install.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Message 5 of 12
Hi @Mark.Lancaster,
Thank a lot for yout reply, i downloaded the 3 parts then double clicked on part 1.. it extract a file( create a folder in C: but nothing happend after that)
Should i click on the 2 other parts ?
Message 6 of 12
mcgyvr
@Anonymous wrote:
Hi @Mark.Lancaster,
Nope.. The first file should start the install and unzip the other 2 files automatically..
Did you download with the virtual agent?
Did you try a clean uninstall after your first issues and prior to trying again?
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Clean-Uninstall-of-Inventor-2016.html
Have you restarted your computer to make sure there are no hung processes,etc..?
Do you have local admin rights on that computer? or click "run as admin" on the first exe file?
Message 7 of 12
Yes, i used the the virtual agent to download the 3 parts. (the 3 files are .exe )
I just restarted my computer and tried again, the first file could unzip the other 2 files automatically but when the installation started it display the same error message as before (There is a problem with this windows installer package. A Dll required for this install to complete could not be run. )
Message 8 of 12
rhasell
Hi
What operating system are you installing on?
It it a new build?
Reason I ask, I had issues with Windows 8.1 a while ago, and the Microsoft system updates would not install correctly, this affected the Inventor install, which would not work until I had repaired my OS. (This was a new build)
Reg
2026.1
Message 9 of 12
Im using Windows 10
Message 10 of 12
rhasell
Hi
Is it a new build and is you OS working correctly?
Reg
2026.1
Message 11 of 12
It is working correctly (it seems)
Does " new build OS" means recently installed ? if yes, no i installed it few months ago
Message 12 of 12
Hello everybody
I have the same issue:
I'm trying to install Inventor Pro 2016 Student on windows 10 (x64), and the same problem occurs.
I tried to dowload from "install now" and from "autodesk virtual agent" (3 files), but it doesn't worked.
I tried "run as administrator" and "run with windows7 compatibility" on the setup of decompressed files from the "autodesk virtual agent's" file, with no success.
I checked the log file to get answers, last lines are reported below:
Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4  SUCCEEDED
Installing Autodesk® Material Library 2016:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\Inventor_2016_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install    Autodesk® Material Library 2016    Failed    Installation aborted, Result=1603
Apparently, this is a frequently encountered issue, but I haven't found a solution. Can someone help me ?
