Error in rule, run on save
When I try to save an idw the following error pops up.
The reason for this error is a location change of the requested file.
I cannot relocate this file to original position. But I do know what the new file location is.
How do I solve this?
Thank you in advance.
Maurits Meijssen
YannickEnrico
I believe you can do two things depending on your original setup.
One is to change the standard iLogic folder (see first screenshot).
The other is to add a new external rule, and remove the old one, and then save the empty file as a new template. (see second screenshot for adding external rule)
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
