Message 1 of 17
Hi all,
I have a bunch of components (currently an iPart table) which all need to be etched with lines which helps with welding/assembly. I need to etch lines to appear on a different layer to the rest of the geometry.
I have tried to emboss these lines straight on to the flat pattern but this required the sketch to be a complete loop, hence my lines are actually loops which is a bit messy. Using emboss causes the lines to be output on layer 'IV_FEATURE_PROFILE' which is fine.
(I have used a circular feature pattern here because the number of etch lines isn't fixed)
Can anybody think of a better way to achieve this?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Visual Studio 2022
