Error in dwg creating and export from Inventor 2020
ArkadNaisir
Message 1 of 33
ArkadNaisir
I am trying to export a part view from Inventor 2020 to Autocad 2020 via a dwg sheet. I did that without issue in the past (different installation, change of computer since)
When I open the file in Autocad I receive the "Drawing file is not valid" error. I am unsure why so but I have suspicion it is because of Inventor when producing the dwg.
Any idea how to solve this (I have tried the unable/enable dwg translator, but changing the status isn't an option for me it seems)
Replies (32)
Message 2 of 33
S_May
... please attach pictures + sketches and models + drawings (pack the models per pack and go + zip), create samples for sensitive data (or please create a screencast), thank you.
Message 3 of 33
ArkadNaisir
Here are a file example
Message 4 of 33
mcgyvr
@ArkadNaisir  Can you please attach the Inventor Drawing of that part. It didn't come through in the pack and go.
Message 5 of 33
ArkadNaisir
Here is the file but I don't use that format, I produce dwg directly.
Message 6 of 33
mcgyvr
??? Do you mean you use/create Inventor DWG files?
If so thats fine. Please attach that file as it didn't come through in the original pack and go.
The dwg file in the pack and go seems to be an Autocad dwg (not an Inventor dwg file) and its corrupt in some way..
Message 7 of 33
ArkadNaisir
The DWG in the zip is the inventor DWG I tried to open with AutoCAD.
Message 8 of 33
ArkadNaisir
@mcgyvr Here is a new fresh version of the inventor dwg I produce, before I try to open it with Autocad.
Message 9 of 33
johnsonshiue
Hi! You did not attach the files here. Please feel free to zip them and attach it.
Many thanks!
Software Test Engineer
Message 10 of 33
ArkadNaisir
I am trying to but the forum fights me.
here is a google drive link?https://drive.google.com/open?id=1F4ZKwiM7bc-c8AxfZ9QJt5LdK_WBGSmy
Message 11 of 33
mcgyvr
@ArkadNaisir  It keeps saying its a non-Inventor dwg file for me and trying to open/import via the standard.dwg template..
I don't use the Inventor DWG format so I may be doing something wrong as I'm not aware of its limitations,etc...
Message 12 of 33
ArkadNaisir
Me either. Would reinstalling from scratch Inventor be of any use?
Message 13 of 33
johnsonshiue
Hi! The dwg file is corrupted. I cracked open. It does seem like it was either exported or saved by Inventor. But, some critical information was missing. I cannot explain the behavior. Also the file size does not make sense. It should not be this small.
Do you know how the file was saved? Could you reproduce it? Do you use any type of encryption tool?
Many thanks!
Message 14 of 33
ArkadNaisir
Here is a video of exactly my step (sometimes I also move the view in model space for autocad)
Message 15 of 33
johnsonshiue
Hi! There is nothing wrong with workflow. Are you saying the file gets corrupted after you saved? It looks like you have quite a few templates. Are you using custom templates? Have the templates been migrated? Also, has the \Design Data\ (styles library) been migrated to 2020?
Many thanks!
Message 16 of 33
ArkadNaisir
From what I know, the templates are the default Metric templates (I would like to have a custom template, but it is an other issue)
I am suggesting that the act of saving corrupts it, since everything before seems fine.
Coming back to a previous post, should I simply reinstall the whole thing?
Message 17 of 33
johnsonshiue
Hi! I don't think the install was an issue. I don't understand why the file becomes corrupted on save. Please share the ipt file also. If you use idw, does it work?
A few things to try but I am not sure if it would help. Go to %temp% and clean up files there. Use Inventor Reset Utility to reset all settings (All Programs -> Autodesk -> Inventor 2020 -> Tools).
Have you installed 2020.2 update?
Many thanks!
Message 18 of 33
ArkadNaisir
Hi, here is the .ipt file, I will try the temp removal. Where should the folder normally be?
Message 19 of 33
ArkadNaisir
Here is the new dwg file after the inventor rest and it still seems corrupted. https://drive.google.com/file/d/1mRCej4ZbAkf55M1U8tj3MzZLUkO79S3J/view?usp=sharing
Message 20 of 33
johnsonshiue
Hi! Did you save it to a local drive or a Google drive? Are you experiencing other file type corruption?
Many thanks!
