error 727492203
error 727492203
ide00518
error 727492203
ide00518
I keep getting this error everytime i open the inventor studio and don't know what's causing it... I really need help... Do you know what it is and what causes it? Any ideas on how to resolve it?
(about inventor professional 2024)
johnsonshiue
Hi! Many thanks for sharing the crash report! I have located the report in our crash report database. It does seem that Inventor crashed right after you tried entering Inventor Studio.
Please make sure all critical Windows updates are installed and the graphics driver is updated. Also apply the latest Inventor update to your release.
Many thanks!
Software Test Engineer
ide00518
I did all the windows updates available 3 days ago and I updated inventor to the newest version but I still get the error. Do you think that if I download an oldest version of the program the problem will be solved? (Considering that I have updated everything else the only thing left is my pc graphics)
Gabriel_Watson
If this happens even with a new file, I would consider reinstalling Inventor. Or right-click the shortcut for Inventor, pick properties, and run it in compatibility mode.
ide00518
I just tried that... Still not working... My last resort probably is to download an oldest version. Do you think that it will work?
johnsonshiue
Hi! What about graphics driver? A quick test to do. In Inventor, go to Tools -> App Options -> Hardware -> select Conservative mode. After that, does it work better? If yes, it means there is a problem with the graphics card. Somehow certain settings might destabilize Inventor.
Many thanks!
ide00518
Turns out the program was too much for my graphics driver... I did everything I could and eventually I changed devices... The inventor 2023 was working slightly better... Thank you for your help! For anyone who has the same problem I think you should download an oldest version. If you are unlucky enough (like myself) and have already made your whole project in inventor 2024 you should know that you probably won't be able to render it or even open it in the oldest version...
