Inventor Forum
Engagement failed because there are different connection properties between fitting and pipe.
0 REPLIES 0
Message 1 of 1
florian.arn
188 Views, 0 Replies
I am trying to build a Custom Cryogenic Hose for the "Tube and Pipe" generator. The Hose is terminated with a Flange at each side.
I created both parts and authored them. The Hose with the the End treatments: Welded and the Flange with the the End treatments: Welded/Flanged. I published them to the Content Center and then created a new Hose style in the Tube and Pipe tool.
Wenn I try to place the hose I always get the Error: Cannot place fitting. Engagement failed because there are different connection properties between fitting and pipe.
I tried to change the end treatments but that didn't change a thing. I don't understand which Connection Properties are the problem
I attached the files of the Hose and Flange if someone wants to test it.
Labels (2)
0 REPLIES 0
