Enabling Dynamic Input in Inventor 2017
It appears that Dynamic input in my inventor 2017 software is not enabled. It is not visible when I draw a line etc. How can I confirm that it is enabled, and if it is disabled, how can I enable it?
LeoAlatorre
Hi!
You can eneable it in the app options, general tab, prompting interaction section
Leonardo Alatorre Zavala
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Luego haga clic en el botón ACEPTAR SOLUCIÓN.
YouTube | LinkedIn
johnsonshiue
Hi! I think you are looking for "Enable Heads-Up Display" option. Go to Tools -> Application Options -> Sketch.
Many thanks!
Software Test Engineer
I've recently drawn a cylinder with a jog and overlap in sheet metal design using Inventor 1017. The cylinder dimensions are 2"dia., by 4-3/4" length. The material thickness is 22 Ga. The jog is Thickness*1.1, and the overlap is 1/2". I made 8 ea triangle cut patterns 3/4" long around the perimeter of one end. My intent is to bend or fold the tabs created from the cut patterns outward to create a flange. I haven't been able to figure out how to draw a sketched bend line on the surface of the cylinder and to bend or fold the tabs outward.
SBix26
@Anonymous this appears to be a completely different problem that you accidentally added on to the end of this thread.  Start a new post about this issue, and be sure to include the file, if possible, or at least a screen capture.
Sam B
Inventor Professional 2017.4
Vault Workgroup 2017.0.3
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
I have enabled the radio button under Tools..Application Options..Head-up display, as well as both the radio buttons under heads up display settings for pointer input and dimension input where possible.  I still get no dynamic input displayed ...very frustrating is there anywhere else that this may be turned off somehow?
