Emboss issue
Emboss issue
Emboss issue
Im trying to emboss the windows by adding 1 mm solid but i get an error whenever i try to do it and when i try to cut it instead it works but not when adding solid.
This should work because I have done the exact same thing with my older finished model. What have I done wrong?
andrewdroth
I'm guessing it's because the sketch isn't parallel to the window, so it's doing weird things in the corners.
I used your sketch to split the window face instead, then thicken the appropriate parts. Let me know if that works.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Thank you for your reply, i fixed it before by just marking the window "glass" instead of the frame and then cut it, which took me 2 days to figure that i could do that hahaha. But now when I try to dimension the windows on my drawing i get errors and I dont know how to solve it.
Here are two screenshots of the problem and here is the ipt and dwg file if you could take a look.
Adding the red marked points as a new member doesn't work and I don't know how to solve it.Adding the red marked points as a new member doesn't work and I don't know how to solve it.I get another error when trying to dimension that 3D sketched edge.I get another error when trying to dimension that 3D sketched edge.
