- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
Hi all,
I have a part that I'm having trouble with, I authored it as a structural shape and published it into the content centre. It just happens to be an elliptical tube, so I sketched an ellipse and then offset it for the wall thickness and extruded it etc.
When I try to place it in an assembly it errors, but other parts I create work fine, it seems to be the ellipse that is causing the failure, I ended up resorting to drawing out an ellipse manually (Stretching the memory banks from tec drawing at school), and this works fine.
Attached are the two files the first with the non-working ellipse and the second .v2 version is the manually drawn ellipse.
I've potentially done something weird with the first version, but I can't figure it out.
There is a clue when you author the part as a structural shape the elliptical version doesn't have a preview in the selection window.
Inventor 2017.4.2
