Hello all,
Currently I'm making a dynamo and need to draw a coil (electrical coil) but I can't find any information on the net on how to do this.
I used the pattern command but it will make all extra parts (coil can have up to 2000 windings). This slows the computer down.
Is there a command I can use to make a coil around a core and makes layers of wire?
Hans
Solved by CCarreiras. Go to Solution.
Hi!
No... there's not such a command to do that, and you don't need it.
Just model a solid representing only the external layer of the wires, or just apply one texture.
This kind of elements will slow down a lot the system with no reason. Just substitute that for a cleaver method
Autodesk apply that method in several things to save memory and increase performence (like you have in the treaded holes, in nuts and srews, get it?)
