Elastic movement of a membrane
Hey!
I have a chamber divided to a pneumatic and to a hydraulic part with an elastic membrane in the middle.
Every time the pressure changes I wanna make the membrane undergo a stress and reflect the respective movement (pressurized/depressurized).
Could that be feasible for simulation?
Cheers,
Manos
swalton
The FEA code in Inventor Pro is limited to small deformation, linear elastic problems.  Think a cantilevered steel bar loaded below yield, not compressing a rubber bumper.
It sounds like your problem will require large deformations and nonlinear materials.  Take a look at the Nastran-InCAD or the Simulation Mechanical packages to see if they are a better fit your problem.
Steve Walton
Inventor 2025
Vault Professional 2025
johnsonshiue
Hi! You might be able to use adaptive part to do that. But, it will be limited to sketch or sketch-based feature. It could be tricky to define the shape and use the appropriate constraint to drive the shape change.
Many thanks!
Software Test Engineer
