Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
As far as I can see, as earlier discussed, the advise is to do not use Patterns in a sketch because with Edit Pattern you can't change the patterned entities or their direction.
Is this still the case in IV2021?
For example, to learn from it, see attached picture of a simple sheet metal based step provided with a non slip pattern based on 'pushed up holes'.
What should be the Inventor approach for a solid parametric design with control of the pushed up hole pattern?
Looking forward your reactions, thanks in advance!
Greetings!
