Inventor Forum
edit sheet format
3 REPLIES 3
384 Views, 3 Replies
edit sheet format
Hello
I have want have a new sheet format as per my requirement & template, is that possible to creat custom sheet format & view.
1) A4 size (4 view)
2) A3 size (4 view) So on
3 REPLIES 3
salariua
Open your template and place the views (any component) then save the template.
When you choose New and use this new template you will be prompted to browse for model (iam, ipt) to show on the preset views.
from the help pages:
Add default views
You can add default base views or projected views to the sheet formats in a template. Use any model to add the views. The template saves the information about the standard views. When you create a file from the template, you are prompted to select the model file from which to create the views
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
in reply to: salariua
@salariua
Sir it will only apply for a single idw. but how to get for every sheet. is there any possibility to make.
salariua
You can only create separate templates. One that stars in A4 model with one view, one that starts in A3 with 2 views, etc.
I have tried to add multiple sheets in drawing templates each with its own number of views thinking that you can delete the irrelevant sheets once drawing is created but that doesn’t work. Only first active sheet gets populated with views even thought Inventor prompts for model selection several times (for all sheets).
Edited:
Only active sheet gets populated with views, not first sheet but active sheet on template save.
Adrian S.
blog.ads-sol.com
