Autodesk Material 4140
jason.dupree
jason.dupree
I've got a client asking about the similarity between materials 4140 and 4142.
From the client:
Currently, I see 4130 and then 4142 with some of the heat treated versions.  From what I've found online, it looks like 4140 is very similar to 4142.  But, I would like to know if Autodesk has anything to comment on the 4140.
Anyone know materials enough to comment on this?
Jason Dupree
Senior Consultant - ECAD, Inc.
danmachen
Some useful info on these materials on makeitfrom.com
i think the difference between 4140 and 4142 is characterised by a different in the Carbon content of the steel (slightly higher in the 4142)
http://www.makeitfrom.com/material-properties/SAE-AISI-4130-SCM430-1.7218-25CrMo4-G41300-Cr-Mo-Steel
http://www.makeitfrom.com/material-properties/SAE-AISI-4140-SCM440-1.7225-42CrMo4-G41400-Cr-Mo-Steel
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
blair
Slightly higher Chromium and Carbon in the 4142 over 4140.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
