Edit Dimension Dialog Box doesn't pop up
At first, when I was creating dimension constraint in 2D sketch the 'edit dimension' box would pop up and it was very helpful to edit the measurements.
Now when I create a new dimension the edit dimension dialog window does NOT pop up.
Tom_Sturtevant
Hi –
This is controlled by Tools > Application Options > Sketch > Constraint Settings > Edit dimension when created.
Hope that helps!
T.0.M.
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
I fixed the issue by right-clicking while in the dimension (enable it there). But I imagine this helps too. Cheers
Tom_Sturtevant
Great!  Now I've learned something from you!
Tom Sturtevant
Autodesk, Inc.
