Edit constraint not clickable
ucheanyanwu598
Message 1 of 18
ucheanyanwu598
  • I want to edit a rotation constraint. I have right- clicked it and I can see "edit" but the "edit" and few other things there are not clickable. It is for a gear I generated.
Replies (17)
Message 2 of 18
b.mccarthy
Can you post something for us to look at?
Message 3 of 18
ucheanyanwu598
This is what I am referring to. The "edit" is not clickable.
Also I would appreciate if you have tips on how to make my gear generator calculator to stop saying "calculation indicates design failure"
Message 4 of 18
b.mccarthy
Can you edit the constraint if you activate the Spur Gear Assembly?
Message 5 of 18
ucheanyanwu598
How do I activate the spurgear assembly?
Message 6 of 18
b.mccarthy
Double click on it.
Message 7 of 18
ucheanyanwu598
Oh is that what you mean.
I just tried it still didn't work. Although now the floating list has more things on it.
Message 8 of 18
ucheanyanwu598
The reason I want to edit it is cuz the gears aren't rotating each other properly.
When I try to rotate them forward using my mouse, they glitch forward and back instead of giving smooth rotations.
A guy had the same issue on YouTube, and changing the direction of rotation solved it.
Or
Is there any other way to solve the issue?
Message 9 of 18
b.mccarthy
If you RMB on the Spur Gear, do you have the option to "Edit in Generator"? This would be similar to editing a frame generator assembly. Does that work? Can you open the assembly, and then edit?
Caveat: I have not worked with spur gears for some years, so I am guessing. Can you post the assembly? If I work with it, maybe that will clear out the cobwebs in my brain.
Also, what version of Inventor are you using?
Message 10 of 18
ucheanyanwu598
  • If I RMB on the gear, I have the option of editing it in the gear generator, but not its rotation
  • I use inventor 2020
  • Attached is the assembly
Message 11 of 18
b.mccarthy
The assembly is missing its components. Please run a Pack and Go, zip the files and re-post.
Thank you.
Message 12 of 18
ucheanyanwu598
So sorry I'm not really a professional, what do you mean by a pack and go?
Message 13 of 18
b.mccarthy
I use 2023, so I am not sure if the process is different for 2020:
From the File menu, select the flyout next to Save As, and select Pack and Go from the options:
I had to run it a number of times using different settings to get what I wanted.
More information here:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
HTH
Message 14 of 18
ucheanyanwu598
I followed the steps you gave me. I hope I followed it right. Attached is the zipped Pack and Go file
Do not mind the two gear part files that I designed without the gear generator. They don't match, I do not intend to use them
Message 15 of 18
johnsonshiue
Hi! Though the Rotational constraint is presented in the gear set, its ratio is automatically computed by the Gear Generator based on the gear diameters. You will need to change the gear design so that the Rotation constraint will change.
Many thanks!
Software Test Engineer
Message 16 of 18
ucheanyanwu598
Okay, are you saying that the ratio isn't meant to be automatically computed?
Or that all the parameters in the current gear design don't match up to produce suitable rotation?
Message 17 of 18
johnsonshiue
Hi! The rotation ratio is supposed to be calculated automatically by the gear generator. If not, it will be a bug.
Many thanks!
Message 18 of 18
ucheanyanwu598
Okay, I will try this
