How2 Export DXF from Inventor 2021
mike.trantham
mike.trantham
Maybe I'm just dumb, but I can't find a way to export DXF from Inventor 2021.  I'm starting from an IDW file.
Frederick_Law
Looks like DWG is the only option, even in 2020.
Electrik
Unless I'm missing something in your question, you can just use Save Copy As, and select your DXF filetype...
Inventor Professional 2021
Vault Professional 2021
Gabriel_Watson
DXF is typically used for Sheet Metal parts. Open your model, create a flat pattern, right-click that in the browser and export/save to DXF.
mike.trantham
Yes, that seems to work. Thanks!
johnsonshiue
Hi Folks,
There is a new option in the Sheet Metal Flat Pattern DXF Export workflow on 2023, mentioned by Gabriel. In the Geometry tab, you may select arcs, instead of lines as the converting geometry for splines. The resultant DXF geometry will be smoother.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-93636DA1-3B31-4EA7-8406-F0CE816310CA
Many thansk!
Software Test Engineer
