Dynamic Simulation
Dynamic Simulation
Message 1 of 10
Dynamic Simulation
This is a YouTube video demo. How to alter the direction of rotation, Position of the nut and traveling distance?
Replies (9)
Message 2 of 10
JDMather
To change the direction of rotation place a minus (-) symbol in front of the degrees of rotation per second.
To decrease the distance of travel - decrease the degrees of rotation per second (Velocity) or decrease the number of seconds of motion.
Message 3 of 10
After initial setting if you want alter the setting. How to change it? Because Insert Joint tool is gray.
Message 4 of 10
JDMather
What book are you using to learn Dynamic Simulation?
This should be covered in the book.
Right click on the Cylindrical Joint and select Properties.....
Message 5 of 10
I am not using any book. This is YouTube video. Can you suggest any e-book?
Message 6 of 10
JDMather
Dynamic Simulation
Message 7 of 10
This is Paperback.
Message 8 of 10
Not able to get in.
Message 9 of 10
JDMather
You must return to the Construction Mode on the Simulation Player to make any edits to the simulation.
Message 10 of 10
Rotation is okay. How to change the Position of the nut and traveling distance?
