Inventor Forum
Dynamic simulation - Test table tipping
5 REPLIES 5
20143382RA7GU
299 Views, 5 Replies
How to check table flipping. I tried everything but the table still wouldn't turn. I adjusted my weight to 50kg but still can't. Does anyone have a way to help me? Thank you very much. I have attached the file below
5 REPLIES 5
admaiora
in reply to: 20143382RA7GU
Can you attach ALL the files?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
I am sorry, I miss part Floor, I have fully updated
admaiora
Hi, i am sorry, there are still misisng parts.
D100.ipt
10 Kg.ipt
Admaiora
D100.ipt and 10kg.ipt I created my own library. I replaced it with the zip file test_table. D100.ipt replaced with loading pad and 10kg.ipt replaced with Weight. Everything is complete, including details, floor, weight and loading pad. You can try again and open it. I tested the simulation again but still can't
Screenshot 2024-04-11 000838.pngScreenshot 2024-04-11 000905.pngScreenshot 2024-04-11 000931.png
Despite the fact that the assembly is still not correct,
the load was placed inside of the green sketched contact area (defined by the  4 "feets").
What do you expext? The table will never tip over, even if you increase the load. (Only the legs will break 😉 ).
Jürgen Palme
Technology Administrators
