Dynamic Simulation Repair Redundancies
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello so I am trying to simulation suspension for a car and when I click and drag in assembly mode, it moves and operates as expected; however, in dynamic simulation mode, it says it is over-constrained by 6 degrees. The very odd thing is that in Mechanism Status, none of the loops have any redundancies whatsoever even though it says there are 6 overall. I can also see which Joints are causing problems, but if I delete them, then it's as if I unbolted it and it can move however it wants.
Any suggestions on what to check next or a checklist I should go through? I would post the assembly, but it is a proprietary project and I am not allowed to do so. 😕 Any help or suggestions would be greatly appreciated. I will post and Kudos the best solution as to what was going on.
