Dynamic Simulation Repair Redundancies
No aplicable
502 Vistas
1 Respuesta
Mensaje 1 de 2
No aplicable
Hello so I am trying to simulation suspension for a car and when I click and drag in assembly mode, it moves and operates as expected; however, in dynamic simulation mode, it says it is over-constrained by 6 degrees. The very odd thing is that in Mechanism Status, none of the loops have any redundancies whatsoever even though it says there are 6 overall. I can also see which Joints are causing problems, but if I delete them, then it's as if I unbolted it and it can move however it wants.
Any suggestions on what to check next or a checklist I should go through? I would post the assembly, but it is a proprietary project and I am not allowed to do so. 😕 Any help or suggestions would be greatly appreciated. I will post and Kudos the best solution as to what was going on.
0 Me gusta
503 Vistas
1 Respuesta
Respuesta (1)
Mensaje 2 de 2
JDMather
The key is to use the correct set of constraints (joints).
What book are you using to learn dynamic simulation?
0 Me gusta
